Need help!! Dunno how2do this excersise
Make a LabVIEW program that counts how many times a given combination of characters included in the label information.
Examble:
In the Search for the combination of: abc
Consisting of the combination of: hoabnjkabcvbchjkabcfga
The result is that the combination of abc occurs 2 times.
(3,023 Views)
The easiest way is to use "Search and Replace String"
Don't forget to wire a true consant to "Replace all"
Just give the search and replace values the same value so the string won't be changed.
UnCertified LabVIEW Student
Mistakes are for learning, that's why suggestions are always welcome!
(3,019 Views)
Now that Koen has given the answer to your homework I may also post an image:
(3,006 Views)
Are you somehow bored guys? Nothing else to do than help lazy students to become incompetent engineers?
(2,993 Views)
That's his own choice.
If he doesn't want to learn it by finding out himself, he'll never learn it anyway.
Though this isn't a really hard exercise, so he will probably still learn from it.
Atleast he now found a new function.
(2,981 Views)
I always read these threads hoping to see some interestingly obfuscated code. 😄
Jim
(2,961 Views)
