Need Update Driver for Tektronix 2440 Oscilloscope???????
Hello all,
I need the updated driver for the TTK 2440 scope. I have the old available from the NI website. Communication is possible with this old driver.It also shows the graph. But the scale settings are not fine(only the X-axis). It seems to take the Xo increment as the X-axis. So say if I set Xo=2 then the X-axis is scaled from 2 to 2 also showing the graph.
I have a doubt if its showing the same graph as on the Scope. Please help me out with this?.
regards,
Vikram Malik
(2,396 Views)
I'm not sure I understand your problem. The X axis is supposed to be the x increment. This is read from the scope and should reflect your sample rate. The only thing I noticed in the driver is that by default it appears to retrieve some pre-trigger data. What exactly is the difference between the waveform you see on the scope and what you see on the graph?
(2,396 Views)
The latest drivers can be downloaded from ni.com/idnet
(2,396 Views)
