05-14-2010 09:37 AM
05-14-2010 09:45 AM
Kim wrote:
thank for the great idea Spectre Dave. I will talk with my customer about that.
Kim,
The standard way of thanking contributors to this forum is to give them a Kudos by clicking the star icon in the top right corner. I am restricted to only giving one Kudos per post and I think Dave's post warrents more than just my Kudos.
So.. can I talk you into giving him a click?
Take care,
Ben
05-17-2010 06:44 AM
Ben
Yes there is an upper limit to the FPGA capabilities and it takes very tight code to pull off the high rates. I typically run my R series at 80Mhz and use pipelining to push the speed.
Thanks for the comment on the Gunship Avatar. That was long ago and far away but I tend to get melancholy around Memorial Day.
05-17-2010 07:41 AM
Spectre Dave wrote:Ben
Agreed!
I just love the LabVIEW solution since it opens doors that aren't easy to open like being able to insert errors on the hardware level. As nice as the the OTS solutions are, they are designed to "work right" and when you are testing, it is often handy to be able to force an error.
Re: memorial day
Yes, same here.
Ben
