Need Help to Stop System Stop Button on my state machine
Accepted by topic author syrpimp
GerdW wrote:
So you need to check your stop condition in all states and in all loops embedded in those states to allow an emergency exit…
Or, as was already said, check the stop button outside of the case structure.  You can use a sequence structure to make sure the stop button is read after the state case has ran.  Then just use an OR to stop your loop (Stop Button OR State Stop Condition Met).
GCentral
Message 11 of 17
(912 Views)
@GerdW wrote:
Hi syrpimp,
something like this:
Depending on conditions I choose the next state. Replace those conditions with your STOP button…
I am sorry, but I don't understand what those T ON boxes are?
Message 12 of 17
(903 Views)
Hi nyc,
TON/TOFF are functions used in PLC programming. I created them for some state machines of mine.
The point of the image is to show how to change state in a state machine depending on conditions…
Message 13 of 17
(900 Views)
@GerdW wrote:
Hi nyc,
To be honest, I have a hard time understanding that small graphic.
Message 14 of 17
(890 Views)
Thnaks GerdW, Al izz Well ....:manhappy:
Thank you & Best regards
syrpimp
“You must continue to gain expertise, but avoid thinking like an expert." -Denis Waitley
Message 15 of 17
(870 Views)
You would be well advised to decouple your user interface from your stae machine by using a Producer Consumer (Events) design pattern.
Then take a trip to Gramma's house and redefine your states.Smiley Wink
"Should be" isn't "Is" -Jay
Message 16 of 17
(865 Views)
Great Help...  Thank you very much Jeff..  I found this info from NI and  yeah you are right I will now shift my code to Producer/Consumer.
Thanks also to
syrpimp
Message 17 of 17
(858 Views)
