12-13-2012 07:05 AM
Hi everybody,
I'm trying to connect a thermo video system camera, via IEEE1394 with a pc, in order to acquiring temperature values from a metallic stick, but when I open Labview (version 8.2) it tells me it's impossible to open the VI, because the lack of msvcrtd.dll in labview. It opens anyway but doesn't run. Where I can find it in the program directory? there's a way to replace it with a not corrupt one? If yes, where I can find the correct dll?
I've attached the file I can't open, it's an example, because every file of that kind (tvs vi's to acquiring temperature) doesn't work without this dll.
Thank you in advance for the help,
Best Regards
12-20-2012 02:02 AM
Hi
where did you find the library to pilot the infrared camera (IrCamCmd.vi, etc)????
12-20-2012 03:33 PM
I found it in the TVS Labview CD-Rom from the TVS supplier, I think it's impossible find it on the net
