NXG Button Turns Black On Hover
Highlighted
Hello All,
I have an unwanted behavior when clicking an NXG button, it turns black when the mouse hovers over it. I have nothing in my code telling it to do this. I've changed the true/false color and added multi Boolean text to the button. Anyone have any pointers to get it to not do this? Thanks.
(214 Views)
Highlighted
Is it just that button?  (If it is, maybe the simple fix is just to replace it.)
Can you supply the button, itself?
Bill
CLD
(Mid-Level minion.)
(157 Views)
Accepted by boomer7010
Don't know about NXG, but in classic LV, a button can have 6 picture items:
  1. False
  2. True
  3. T->F
  4. F->T
  5. False rollover
  6. True rollover
It could be that the rollover picture items are set to black images.
(125 Views)
Highlighted
@boomer7010 wrote:
Hello All,
I just noticed the same thing happening today and happened to see this topic.  Paul has the right idea on why this is happening.  With the original NXG button everything is fine.  But when I changed the true color to green using the properties on the appearance tab LabVIEW changed 2 states to black.  I would go with a bug.
Since I already have about 40 buttons with this issue, what would be the best way to correct the issue?  Modifying 1 button at a time does not sound fun.  I am actually using the buttons as status indicators, that is why I was changing the T/F colors.
I am using LV2018 and just tried 2019 SP1 and had the same issue.
(116 Views)
Highlighted
Sorry for the late reply. It seems the only fix is to create a custom control and change the 2 of 6 colors to the desired colors. Thanks all for the replies.
(69 Views)
