02-16-2021 11:45 AM
Anyone please tell me how to read serial data using NI 9870 Module in Labview? Can someone please share a code to do this in labview
TIA
02-16-2021 01:44 PM
Hi Zaman,
did you even try to search the web for examples?
A simple search for "labview ni9870 sample code" gave this as the first result…
02-24-2021 08:15 AM
I just check these all but it didn't work for me as all are complex codes and I am very new to this. Can you please help me in writing a code that just read serial Rs232 data which I receive from module NI- 9870.
Awaiting for the reply
TIA
02-24-2021 08:23 AM - last edited on 04-04-2024 02:14 PM by Content Cleaner
Hi Zaman,
When you are new to LabVIEW you should use the Training resources offered in the header of the LabVIEW board to learn LabVIEW…
As has been written on the page I linked to:
The NI 9870, 4-port serial C-Series Module, was made to work with the cRIO in FPGA Interface Mode. The programming required for this module is a little more advanced than some of its analog and digital cousins.
You have choosen to use a module, which requires a cRIO and programming in FPGA mode - so you need to learn the basics of LabVIEW-Realtime and LabVIEW-FPGA to be able to facilitate that module!
