[NI myDAQ] Function generator/oscilloscope
Hello there.
I tried to seach some stuff and read tutorials but I'm still having one doubt: can I use the function generator and oscilloscope at the same time (I'm working on operational amplifier)?
Thank you.
(3,822 Views)
Bom dia.
Eu possuo um myDAQ e estou fazendo uns testes com a saída de amplificadores operacionais e gostaria de saber se o referido instrumento consegue gerar funções para um dado circuito e também operar como osciloscópio simultaneamente.
Desde já agradeço.
(3,800 Views)
When you say 'at the same time', do you mean in the same frame? Or are you referring to a delay in the same frame?
(3,774 Views)
Simultaneously, using the same myDAQ for both measures.
simultaneously
(3,768 Views)
Accepted by topic author GustavoAraujo1
Yes, as far as I know, it can be done. However, the oscilloscope works best with some delay. Otherwise, the oscilloscope will start reading data points before the actual signal is received. These data points that your oscilloscope is reading will essentially be noise.
(3,765 Views)
