05-15-2006 04:37 PM
05-16-2006 12:43 PM
The KnowledgeBase entitled Using NI Hypertrend and Alarm & Event Display with Remote Panel says that,
" This is a known behavior you are seeing. In general in LabVIEW, you cannot view ActiveX controls or objects when using Remote Panel. ActiveX controls embedded on a front panel do not display on a remote client because they draw and operate almost completely independently of LabVIEW. The NI Hypertrend object and the Alarm & Event Display are ActiveX based. Thus they are not supported in Remote Panel. Try using non-ActiveX objects such as the Historical Trend indicator or the Alarm Summary Display Listbox instead."
Here is a related discussion forum that reflects how this object will not work with remote panels...
Browser can't load HyperTrend in a Remote Panel Application
Sorry to be the bearer of bad news! You might have to use the Historical Trend indicator to meet your application needs.
