07-01-2014 11:28 PM
We are now working with 'CompactRIO Real-Time Controller - NI cRIO-9004', and facing many problems.
hardwares we're using:
chassis: cRIO-9104
modules: NI 9472, NI cRIO-9411, NI cRIO-9221
Softwares we're using:
NI ACADEMIC SITE LICENSE Fall 2010
NI LabVIEW Core Software
Extended Development Suite
Control and Embedded Systems Software
Signal Processing and Communications Software
NI Device Drivers DVD August 2010
NI MAX updated to 5.6
developer computer: Windows 7 profesional.
our Problem:
Use NI MAX connect cRIO-9004, it displays "Safemode (improper installation)". I installed the software for cRIO-9004 for several times, it still display this information.
Besides, the 'Status LED' on cRIO-9004 flashes two times continually, which means software is interrupted according to the manual.
07-02-2014 12:51 PM
Have you tried reformating the cRIO-9004 and reinstalling the software on it? I've attached an article that goes over how to do this.
http://digital.ni.com/public.nsf/allkb/6B1343F61905203386257051006573CA
Let me know if this helps, it should.
07-03-2014 08:49 AM
Thank you, Rob.
I've reformat the controller for several times. It still didn't work. Always the same problem appeared, i.e. "safemode improper installation".
07-07-2014 08:02 AM
Can you double check the physical dip switches on the controller and ensure that the "Safe Mode" switch hasn't been inadventently switched to the "On" position? Also, what versions of NI-RIO and LabVIEW Real-Time are you currently using?
