09-02-2026 04:11 AM
I am trying to read an IMU connected to a NI PXI-8512 CAN interface using LabView 209 and NI-XNET 2019.
The PXI-8512 is correctly detected in NI MAX, where I can see both CAN1 and CAN2 interfaces (see attached NI MAX screenshot).
However, when I create an NI-XNET session in LabView, I cannot select CAN1 or CAN2 from the interface dropdown.
Could someone please advise how I can correctly select/configure CAN1 (or CAN2) in LabView?
Thank you!
Solved! Go to Solution.
09-02-2026 06:41 AM
Hi macs,
Questions:
09-02-2026 06:48 AM
Hi GerdW,
Thank you for your quick reply,
- Yes I use the very same versions: LabView 2019 and NI-XNET 2019, sorry for the typo.
- The VI is currently running on my development computer.
macs
09-02-2026 09:03 AM
Hi macs,
The VI must be prepared to run on your remote system!
The local system doesn't knows about any CAN ports, only the remote system can handle them…
09-03-2026 12:32 AM
To echo what GerdW has shared, make sure you have a Real-Time target in the LabVIEW project and place the VI underneath it.
09-03-2026 03:34 AM
Thank you very much GerdW and ZYOng! Indeed it worked 🙂
Best,
macs
