NI-XNET cannot find CAN1/CAN2 in LabView although they are visible in NI MAX
I am trying to read an IMU connected to a NI PXI-8512 CAN interface using LabView 209 and NI-XNET 2019.
The PXI-8512 is correctly detected in NI MAX, where I can see both CAN1 and CAN2 interfaces (see attached NI MAX screenshot).
However, when I create an NI-XNET session in LabView, I cannot select CAN1 or CAN2 from the interface dropdown.
Could someone please advise how I can correctly select/configure CAN1 (or CAN2) in LabView?
Thank you!
(840 Views)
Hi macs,
Questions:
  • Do you use the very same versions of LabVIEW and XNet (both 2019)? LabVIEW2009 might not work with XNet2019…
  • Where do you run your VI? Does it run on your development computer or on your remote device? Unfortunately you don't provide tat information with your images…
(819 Views)
Hi GerdW,
Thank you for your quick reply,
- Yes I use the very same versions: LabView 2019 and NI-XNET 2019, sorry for the typo.
- The VI is currently running on my development computer.
macs
(812 Views)
Accepted by macs74
Hi macs,
The VI must be prepared to run on your remote system!
The local system doesn't knows about any CAN ports, only the remote system can handle them…
(785 Views)
Accepted by macs74
To echo what GerdW has shared, make sure you have a Real-Time target in the LabVIEW project and place the VI underneath it.
(762 Views)
Thank you very much GerdW and ZYOng! Indeed it worked 🙂
Best,
macs
(748 Views)
