01-09-2015 04:43 AM
Hi everyone..When building an application in labview,you have the option of including additional installers (National instruments Installers)..if i include N.I VISA Run time 5.1.1 in the installation but the computer of a given user already has N.I VISA Run time 5.1.2, the installation will fail in that user's computer...it gives the error:
Cannot install
Run Time Support (higher version already installed)
Is there way of preventing this from happening or going around this problem?.for example incase the installation process detects a higher version of the NI-VISA,it automatically adapts to that one and goes on with the installation process.Thanks in advance
01-09-2015 07:22 AM
Does the installation actually fail? My understanding was that the NI drivers are mostly backwards compatible so if you have a newer version installed it will tell/warn you that a newer version is installed but the installation will continue and the application should work.
Is that not what you're experiencing?
01-09-2015 07:34 AM
no,at some point during the installation process you cannot click "NEXT" to proceed and it says :
Cannot install
at this point your only option is to cancel the installation process...:(
01-09-2015 09:18 AM
Can you include a screen shot or two that shows the failure and the windows view imediately previous to that?
My experience is that is simply skips that driver and continues with the remaining install also.
01-09-2015 09:27 AM
Cannot install
- NI-VISA 5.1.1 (higher version already installed)
You get that "no-other option" only if everything that can be installed is installed and the only thing left to install that you wanted to install cannot be installed.
Or, more simply, you can only cancel because no installation is available to install. There is no "Next" because nothing is left to do. Normal Windows install behavior! (If I was the MSI designer the button would read "OK" and not "Cancel" but i'm not multi-lingual)
01-09-2015 09:43 AM
oh!! yes..thanks..i actually hadnt checked if it had installed anything...thank you very much!!
06-01-2015 01:46 PM
Hi..While using LabVIEW 2013 version i experienced a problem.. I am unable to use VISA resourse name as nothing is displayed in it(like comm 1 /comm 2)..
It only shows refresh tab..What could a possible solution to it..
06-01-2015 01:49 PM
