NI-VISA 16 on windows 10 64-bit Driver power state failure
I was set Greek Region Settings and I changed to English (USA) but the same results. I' m gonna use the same installations on windows 7 32 bit on the same PC to check if it's an operating system problem or my hardware and drivers. Thanks for your help.
Message 11 of 13
(2,139 Views)
The same results on WIndows 7 32 bit on the same laptop. When windows 7 loads a blue screen appears again and windows restarts.
Message 12 of 13
(2,136 Views)
This really sounds like either
a) a BIOS issue or
b) a corrupt installation media
As you tried the downloaded NI VISA installer only as well as the driver DVD, is assume that option b) is VERY unlikely.
I recommend to check with a totally different system. If that works correctly, you have pinpointed the issue to a hardware/BIOS issue on the specific computer.
Norbert
Norbert
Expert: Geometry
Message 13 of 13
(2,127 Views)
