NI Update Service - RT 2019 Sp1 Info Link Not Working
NI Update Service is telling me that 2019 f1 (http://www.ni.com/r/rt2019sp1patch) is available.
The link in the information section does not go anywhere - http://www.ni.com/r/rt2019sp1patch  just loads http://www.ni.com/placeholder
Where is the information on this update available?
Ryan
Ryan Vallieu CLA, CLED
Senior Systems Analyst II
NASA Ames Research Center
(2,117 Views)
If you are running the NI Update Service from your PC, then it should enable you (from within itself) to download and install whatever Updates you select.  Note that by default, it shows "Critical Updates", but I think there's a button somewhere that shows Updates, where you should see the SP1 version.  Select and sit back ...
(2,093 Views)
Yes, it will download, but I wanted to read the descriptions of the included changes.
(2,087 Views)
