NI USB 8502 CAN device and Pharlap
Can we use NI USB 8502 CAN device in a PXI RT running in Pharlap OS?
(276 Views)
What you want to need with Ni 8502 in PXI RT?
What kind of PXI you are want to use?
PXI Modules (PXIe-8521, PXIe-8522, and PXIe-8523) do not support the Phar Lap ETS real-time operating system that installs with the LabVIEW Real-Time Module.
(202 Views)
Not sure if the answer is yes or no, but the answer is definitely NO for a new system.  If this is just to test something really quick, even if it's not supoprted, you may be able to get it to work.  I would just install XNET to the PXI controller and see if it populates.  If it doesn't, i would spend 30 minutes Google Fooing and SSHing and then I'd give up.
Pharlap support is ending this year so please don't start a new system with it.  Bite the bullet and invest in new hardware.  Save headaches down the line.
Ben Johnson
ʕง•ᴥ•ʔง
(178 Views)
