NI USB 8451 with Sigma Delta ADC interface
Hello everybody,
I really apreciate it if you could let me know how can I record online SPI stream from ADS1278 Sigma Delta ADC without any delay.
Is it possible to use NI USB 8451 card to receive non-interruptable SPI data stream ?
Thanks a lot,
(3,189 Views)
Should be possible, as long as your data rate is within the spec of the 8451.   Can't remember it offhand.  What's the clock rate on your data?
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
(3,187 Views)
Thanks a lot,
The clock is 10 MHz.
I had a worry if the streaming would be continous on the software side on the computer.
Do you think it is feasible ?
Can I use one-way data transmission (no feedback)?
Thanks a lot,
(3,184 Views)
10 MHz is a bit high.  I don't think I ever took the 8451 above 500 KHz -- so I don't know for sure.
-Matt Bradley
(3,171 Views)
