07-21-2009 02:13 AM
I am using LabView v8.6. I have a NI USB 6501 device. In my application i want to give a train of pulses as an input, count the number of pulse in up or down direction that will be selected by the user(on front panel) .And also i want to output that train of pulses on some other line. Since i am a new user i could count only in one direction and that too if i use the counter (p2.7). So can the counting be done in software by use of some logic?
I would appreciate your help.
Thank you.
Regards
Mr. Rohan Kanitkar
08-11-2009 05:52 AM
Please refer to the following links , it clearly explains use of 6501 as counter -
http://forums.ni.com/ni/board/message?board.id=170&message.id=279473&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=40&message.id=7305&requireLogin=False
http://forums.ni.com/ni/board/message?board.id=40&message.id=7136&requireLogin=False
Pranchal
