05-03-2024 07:48 AM - edited 05-03-2024 07:55 AM
I have USB-6001 that I used a few versions of LabVIEW ago (no longer installed). My current Windows laptop has LabVIEW 2022 Q3 installed and I am trying to create a simple application to use the USB-6001.
When I plug the DAQ device in, it appears in both the Windows Device Manager and NI Max
but this is all I appear to be able to do with it.
When I try to create a new task for anything, I get this:
Any clues?
05-03-2024 07:52 AM
DAQmx is installed? Try to reinstall it first.
05-03-2024 07:58 AM - edited 05-03-2024 08:04 AM
I thought so! I have all the DAQmx stuff in the functions menu:
And if I run the NI_DAQmx installer I get this.
05-03-2024 08:32 AM
As I recall (when it happened to me maybe a decade ago), when a DAQ device such as a USB-6001 shows up in MAX as something other than "dev1" (or some other number), but as USB\VID_nnnnnn, that is a sign that the driver is missing, so DAQmx can't "do its thing" and handle it as a "dev"ice.
How to fix this? In my earlier LabVIEW experiences (in the early 20-teens), I (once or twice) tried to "repair" a LabVIEW installation (such as "DAQmx"). This procedure typically took many tens of minutes, sometimes hours. Much faster was to uninstall LabVIEW (all versions, which, at the time, was usually 2 or 3) and re-install (took a few tens of minutes). The same is probably what I'd do today, as well.
Before you do, however, please supply some additional information:
05-03-2024 08:52 AM
Ah - well .. I have already embarked on a 'repair' of - what I thought was DAQmx only, however, maybe I didn't deselect things and it is, as you say, taking ages. Now I don't know if it's wise to stop it as I might end up with a partially repaired system.
One thing to note is that I also installed the community edition to use for my own projects rather than my consultancy stuff - so it's possible that has complicated things!
I am running LabView 2022 Q3 32-bit. Although it quotes my correct paid-for serial number, it now also says 'community edition' on the About screen. I think this is a bug and that only appeared since I installed the community edition.
The community edition is 2024.
I did the installation - I am the owner and administrator of this computer.
This the screenshot of the MAX software tab:
For some reason, MAX makes the text tiny - I can't tell how legible it is until I post this answer - it looks fuzzy in this preview.
05-03-2024 09:02 AM
You have DAQmx 22.5, try to update to the latest version 2024Q2, should be compatible with previous version.
Could be interference with Community Edition, but pretty sure, I have had similar "combination" and LabVIEW Professional installed side by side was functional with USB I/O.
05-03-2024 10:14 AM
OK Andrey , I will try the latest DAQmx if this current repair doesn't work; I didn't want to install that and find it broke my LV 2202 Q3.
05-03-2024 10:31 AM
Hopefully will be not broken. Here is NI-DAQmx and LabVIEW Compatibility Table, but as usually NI do not track very recent versions , so we can just "propagate" this to the latest version.
Anyway, DAQmx 2023 Q3 is officially compatible with your 2022 Q3:
