NI Teststand giving error
NI Teststand is not allowing to reload the VI and its giving this attached error . I am using NI Testsand 2017 with labview 2017 as an adapter . I changed and tried all the possible ways to make it work as per the NI suggestions but still unable to make it work . Any suggested beyond the NI website would be greately helpful.
Thank you
(436 Views)
Would you mind telling us what things you did try, with specific details if possible?  It's entirely possible you missed something that is a "NI suggestion" but if we assume you did it, and it didn't work, that wouldn't really help anyone.
(401 Views)
Hi kotha,
did you change the VI, especially anything related to its connector pane?
Did you update the step in your sequence to adapt to the changed VI conpane?
(375 Views)
