NI RIO installation error for windows 8 Labview 2016
I wish to interface my windows-8 laptop with NI 9205 via NI c-DAQ 9172. In the process I got the correct driver which reads 9172, but it does not read NI 9205, NI 9263, NI 9401 modules which are already attached.  So, I saw that first you install NI RIO and then update it with  NI RIO210f1 to make ot work. When I try to instal NI RIO, I get the error
The windows installer engine is corrupt. To attempt to resolve this issue, please register the engine by running regsvr32.exe or mki.dll .
What is the problem and how do I proceed.
Does NI 9205 work with windows 8??
(2,670 Views)
Hello Anuj_Kuruwa,
for a cDAQ 9172 you need the NI-DAQmx driver, this driver should support the moduls and chassi. The NI-RIO driver is needed, if you work with  our Real Time targets like cRIO 9039 and so on.
What LabVIEW Version do you want to use?
best regards
Alexander
(2,663 Views)
I had installed the NI-daq15.1 version and Labview is reading NI daq 9172 but not the module of interest which is NI 9205 and NI 9263. When I tried to install the NI-daq1610f3 it shows the following error- The application was unable to start correctly (0xc0000018). And I still don't know the source of NI RIO error even if I am not using a real time module.
(2,627 Views)
Hello Anuj_Kuruwa,
can you try this
Errror 0xc0000018 when running DAQmx 16 on Windows 10
  1. Press Win+R and type regedit
  2. Go to HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\­Microsoft\WindowsNT\CurrentVersion\Windo­­ws
  3. Than search for APPINIT_DLLS and delete the default value
  4. Reboot
best regards
Alexander
(2,623 Views)
