NI PCI-6259 rename
In a new computer means what about the DAQ card. If that code calls task then you might have to create one and also as you said you have to rename. Did you try what I suggested?
Message 11 of 14
(746 Views)
I am a newbie to LabVIEW, I don't know how to create a task.The DAQ is in the new computer and shown in the device manager.  Here are two screen shot. The top one is the MAX in new computer, the bottom one is the MAX in old computer. The MAX in the old computer is in an older version.
Message 12 of 14
(742 Views)
Try reinstalling the DAQmx drivers on the new PC.  It seems odd that the card shows up, but not under the DAQmx Devices branch of the tree.
Message 13 of 14
(722 Views)
I have installed it two times. Can it be the problem of the MAX version?
Message 14 of 14
(707 Views)
