I am trying to connect to a Gaussmeter IGM11 through an ethernet connection. I have it's IP adress and can ping through command promt but using VISA in NI-MAX requires a port number when using socket connection.
When I create a new device and interface in MAX, choose VISA TCP/IP Resource, both the Manual Entry of LAN instrument and Manual Entry of Raw Socket require a Port Number. I have entered the port from command promt 319 and 23, but MAX replies with "Could not open a VISA session to "TCPIP0::192.168.0.8::319::SOCKET". Error code 0xBFFF0011.
How do I determine the port number to enter and start a valid VISA resource?
Thanks & Regards
Vijay
