NI Instrument Driver Finder did not return any results
Operating system: Windows 10
Software: LabVIEW 2023 Q1
(2,279 Views)
I usually start at the the equipment manufacturers website as they will have the most up to date drivers for their instrument.
Then try looking in the Instrument Driver Network (IDNet)
=== Engineer Ambiguously ===
(2,259 Views)
Also me facing this issue; did anyone find a solution for this fault ?
(2,153 Views)
Hi Hamoda,
did you notice message #2 from RTSLVU?
(2,147 Views)
Hi GerdW
Yes i noticed it, but i'm trying to fix this issue as it's more easy and fast to Plug Instrument and Install driver directly instead of two or three steps.
(2,142 Views)
@HamodaGA wrote:
Hi GerdW
Right, NI is trying to make it easier, but honestly you can't depend on this working (as you can see) or providing the most recent instrument driver when it does work.
Every instrument manufacturer writes their own drivers, some are contracted out to NI, some are even written by LabVIEW users. But all of them are voluntarily provided to NI's Instrument Driver Network instrument manufacturers are under no obligation to provide a driver to the IDN nor is NI.
(2,115 Views)
I have the same problem , and yes I finally found a driver and installed it manually
HOWEVER
This is still an annoying malfunction in the LabVIEW IDE and should be fixed!
Greetings from Germany
Henrik
LV since v3.1
(2,091 Views)
