NI Goop Wizard not working with LabVIEW 2009
I have added the NI Goop Wizard using VIPM (VI Package Manager) into my LabVIEW 2009 SP1 installation however it is not working. Whenever I select Create New Class from the drop down (same applies to menu selection) nothing happens and the drop down returns to it's default selection. I have tried this on 2 PC's both with 2009 SP1 installed, both exhibit the same unwanted behaviour. One of the PC's also has LabVIEW 8.2.1 installed also with NI GOOP Wizard and this installation works fine.
Anybody using GOOP Wizard with 2009 ?
Cheers
Chris
Don't forget to give Kudo's for a good answer !
LabVIEW Champion
Certified LabVIEW Architect
Certified TestStand Architect
(2,491 Views)
Hi there Chris,
Off the top of my head it's my understanding that NI GOOP wizard is legacy software that was made redundant by the native GOOP tools in LabVIEW 8.2.0 and later.
In light of this it's a bit confusing that everything is working fine with 8.2.1 for you. Is there a version to the NI GOOP Wizard that you are using?
I had a search across the website but I'm afraid I haven't found any other examples or poeple using the GOOP Wizard in LabVIEW 2009 or 2010.
Kind Regards.
Rhys
(2,439 Views)
