NI GNSS Simulation Toolkit, One Example not installed
Hi All,
I have downloaded and install the toolkit but did not get one of the example(mentioned in the read me/Doc http://zone.ni.com/reference/en-XX/help/372446D-01/nigpshelp/gnss_simulation_modes/) after the installation of the toolkit.
All the examples has been installed but did not able to find the example "niGNSS Streaming from TDMS file.vi example"
Can one please help me to find the out the example "niGNSS Streaming from TDMS file.vi"?
Thanks in advance.
(951 Views)
Hi LV_Coder! How are you?
I installed the NI GNSS Simulaton toolkit as well to try finding it and I could manage to do so by
following this path:
This PC>>(Your HardDrive disk)>>Programs Files (x86)>>National Intruments>>LabVIEW 2012>>Examples>>
RF Toolkits>>GNSS>>Programming>>GNSS>>SingleRFSG>>niGNSS Straming From TDMS File
I've attached an image below wih this same path just in case. If you still can't find it or have any other question please just let me know.
Lucas Freitas
Technical Support Engineering
National Instruments Brazil
(877 Views)
Hi Lucas Freitas,
One more query, Does NI GNSS Simulation Toolkit support signal generation on RT Platform, real time operating system?
(834 Views)
Hello Lucas and LV_Coder,
I have installed GNSS 3.0 but on my PC the path you showed contains slightly different files. Please see the attachment.
To which GNSS version did you refer?
Could you eventually post here the niGNSS Streaming From TDMS File?
Thank you
Raffaello
(182 Views)
