NI DMM Read freeze during second iteration on Read DMM
Hello All,
I am using 4082 DMM for voltage measurement and it works in pharlap RT environment.
For continuous measurement purpose in am calling the DMM read in Loop until in close my application.
For first read it works fine and during second iteration it gets freezed in Read DMM vi.
This issue occurs when the module is called as a part of my project.
When running the module individually it works fine
Note: none of the information is been sent from the project/ calling module, only it gets launched on need basis.
Same project works fine in other machines perfectly without any issue.
Please do suggest on what reason it gets freezer on second call.
(624 Views)
Similar issue faced long back in one of our system, after Un-installing and installing all the LabVIEW software it got worked.
Tried same this time but no luck
Labview version used in LV 2017 SP1
(612 Views)
