04-22-2009 04:47 AM
I have both LabVIEW 8.0 and LabVIEW 8.6 installed on my laptop running Windows Vista. After the successful installation of NIDAQmax 8.7.1, NI-DAQmx is only available in LV 8.0, but not LV8.6. In LV8.6, can only see MAX configuration under 'Measurement I/O'. Can anyone help on this? Thank you.
(I need DAQ assistant for my application coded in 8.6)
04-22-2009 04:58 AM
Try to install it again and check if you have added support for LabVIEW 8.6.
Christian
04-22-2009 05:19 AM
Hi, Christian
Thanks for your prompt reply. I run the installer again, but it seems that NIDAQmax 8.7.1 does not have support for LabVIEW 8.6, it only got support for up to LabVIEW 8.5. Should I download a higher version DAQmax?
04-22-2009 05:38 AM
04-23-2009 04:17 AM
04-23-2009 04:35 AM
04-23-2009 04:41 AM
I see. Thanks for your clarification. Kudos was given to you to express my appreciation.
