08-09-2018 03:05 AM
I am using "NI USB-6001" for my application, and created the code in "Lab view 2016" for data acquisition. I will modify the code and test it with a new 6001 every time.This VI is present inside a project.
When i drop and click on the pull down arrow of "Global virtual channel constant" to select the lines to read, nothing is happening. Even "Browse " is not listed there.
Is it related any Max Configuration ?
The "DAQmx Task Constant" is also not working even after the tasks were created in MAX.
I already have the old "Global virtual channel constant" in the code, and when clicking on the drop down menu , nothing happens. i have deleted the old "Create Channel VI" as well and created a new one, reinstalled the NI DAQmx several times. but still the problem is not solved.
Any one faced this problem ?
I am facing this problem in more than one PC both updated with NI DAQmx ver.18
Solved! Go to Solution.
08-10-2018 10:01 PM
Hello oopesh689,
There is a difference between a Global Channel and a DAQmx task as explained in: Channels and Tasks in NI-DAQmx
In the image you attach (max config.jpg) you show 4 DAQmx tasks and zero Global Channels. I wouldn't expect the DAQmx Global Channel constant to show anything, since there are no Global Channels defined in NI MAX.
If you want to use the data acquisition settings you have in NI MAX, I recommend you use a DAQmx Task Name Constant.
Additional resources to check out:
All the best,
08-17-2018 12:44 AM
Thank you for the comment.
I have reinstalled the LABVIEW development software and Daq Mx 16 drivers.
As you said , i have created the Global virtual channels as well as tasks in MAX and saved it.
Now that i have created everything , it should appear in the vi at the channel or at task constant right?
Please see the attached images . Even the channel controls ,constants , task constants does not shows anything when you click on the pull down button.
Am i missing any drivers?
08-17-2018 01:01 PM
roopesh689,
Can you try with the VI I attached? It has different constants, and I would expect it to show your Global Channels and Tasks in the dropdown.
If all of them are still empty, even when your device is plugged to the computer, I would follow the next steps:
Keep us posted. All the best,
08-18-2018 08:10 AM
Thank you.
As per the steps you said i made a back up of the MAX configuration. Reset the Max Configuration.
Then imported the old configuration.
It is now working fine.
