I tried to use the example acquire1Scan.c to acquire a simple voltage on my 6008. It returns the following message: ZeroLink: unknown symbol '_DAQmxBaseCreateTask'
The NIDAQmxBase.h is located in the "Other Sources" folder.
I should forget something...
Thank you for your help.
Daniel Jean
#include "NIDAQmxBase.h"
#include
#define DAQmxErrChk(functionCall) { if( DAQmxFailed(error=(functionCall)) ) { goto Error; } }
int main(int argc, char *argv[])
// Task parameters
int32 error = 0;
TaskHandle taskHandle = 0;
char errBuff[2048]={'\0'};
// Channel parameters
char chan[] = "Dev1/ai0";
float64 min = -10.0;
float64 max = 10.0;
// Timing parameters
uInt64 samplesPerChan = 1;
// Data read parameters
float64 data;
int32 pointsToRead = 10;
int32 pointsRead;
float64 timeout = 10.0;
DAQmxErrChk (DAQmxBaseCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxBaseCreateAIVoltageChan(taskHandle,chan,"",DAQmx_Val_Cfg_Default,min,max,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxBaseStartTask(taskHandle));
DAQmxErrChk (DAQmxBaseReadAnalogF64(taskHandle,pointsToRead,timeout,DAQmx_Val_GroupByChannel,&data,samplesPerChan,&pointsRead,NULL));
printf ("Acquired reading: %f\n", data);
Error:
if( DAQmxFailed(error) )
DAQmxBaseGetExtendedErrorInfo(errBuff,2048);
if( taskHandle!=0 ) {
DAQmxBaseStopTask(taskHandle);
DAQmxBaseClearTask(taskHandle);
printf("DAQmxBase Error: %s\n",errBuff);
return 0;
