05-22-2019 03:47 AM
Hi Team,
Has anyone else had issues installing and using DAQmx 19?
I have LV15 (32-bit)*, 18 (32+64bit), 19 (64-bit) and then installed DAQmx 19.0 without error. However, now none of the ADEs are able to use the driver.
From MAX I can confirm I have:
And the drivers were installed after the ADEs
I have already reinstalled the driver and have been through the following articles:
Can’t Find NI-DAQmx Functions after LabVIEW or NI-DAQmx Install
DAQmx Functions Doesn't Appear in LabVIEW Functions Palette
Upgrading or Downgrading LabVIEW with NI-DAQmx
*2015 isn't supported by 19.0, but it should still appear in the other LV versions.
Any thoughts? Known issue?
05-22-2019 03:53 AM
There are three potential reasons i can think of:
1. During installation, you can uncheck options. Maybe the option to install the LV API was unchecked for whatever reason
2. It could be a user right conflict. Are you using the same user to install both LV and DAQmx? If not, has LV been installed for "this user only" which prevents the DAQmx installer to access LV because of missing access rights?
3. LV installation directories are write protected against the DAQmx installer
05-22-2019 03:59 AM
Hi Norbert,
Thanks for the quick reply!
The only thing that was unchecked was the Ethernet cDAQ Firmware option (unchecked by default)
