NI CAN sbRIO-9628
Hi ,
@GerdW
sbRIO9628 does not support NI embadedCAN. and it support NI Xnet .
I'd like to know how to send a frame to another device via the sbRIO's CAN port.
I've included the software I downloaded for sbRIO below, and I'd appreciate hearing your thoughts on my suggestion.
Thank you.
(1,196 Views)
Hi Emna,
@Emna20 wrote:
Hi ,
@GerdW
Is there a reason you explicitely mention my alias? (I just found this by chance, I don't get any notifications when someone writes my alias in his/her message…)
As can be seen in this image you already can send a dataframe using the IO node in the FPGA.
What else do you need?
(1,170 Views)
Hi ,
Thank you for your response.
I mention your alias because I found a related subject where the solution is delivered under your name.
I just want to know if my suggestion is correct ? and if sbRIO9628 support I/O node in the FPGA.
and is there any NI training about using CAN with sbRIO ???
Best Regards.
(1,141 Views)
Hi Emna,
In this case it would have been nice to provide a link to that solution…
@Emna20 wrote:
and if sbRIO9628 support I/O node in the FPGA. and is there any NI training about using CAN with sbRIO ???
I don't think there is a special "training" for "CAN on sbRIO". Check the examples coming with LabVIEW/RIO for using "CAN on FPGA"…
(1,135 Views)
