NI 9234 : sampling rate : cRIO, FPGA
For NI 9234 module, front panel and block diagram of my FPGA code of my cRIO is like below.
The sampling rate (data rate) is selectable between some values as shown below.
Do you have any idea how I can do the sampling with a lower rate that is smaller than the samllest option (1.652 KS/s)?
(4,111 Views)
Accepted by topic author Cashany
Hi Cashany,
Take a look at this link. Page 16 describes the limitation that you are running into. Basically the master time base can only be divided down to certain data rates because of the way the device physically handles digital and analog filitering. So there really isn't a way to divide down past that point.
Ryan
(4,089 Views)
Thanks. I solved my problem by another method. My solution is in the following link:
http://forums.ni.com/t5/LabVIEW/DMA-FIFO-from-FPGA-to-RT-host-gets-full/td-p/2509316
(4,085 Views)
