NI 9214 on cRIO 9014
Hi everybody,
I'm working on a Windows 10 laptop and I'm trying to acquire data from a NI 9214 thermocouple module with a cRIO 9014, connected with Ethernet cable.
I have already installed Labview 2015 on the cRIO and correctly connected.
I am also able to read temperature data from the thermocouples by means of NI Distributer System Manager.
The problem is that I cannot view the module under the Chassis in the Project Explorer and I cannot add my channels blocks on my VI.
How can I solve it?
If I go on Properties on the Chassis it shows me an "Unexpected Error".
I've already formatted the cRIO and installed Labview again several times.
Thank you very much in advance,
Lorenzo
Message 1 of 14
(4,525 Views)
What happens if you right-click on the cRIO and choose new->C-Series Modules.  Will it detect anything here?
Message 2 of 14
(4,510 Views)
If I choose "new" there is no " C-Series Modules".
I also tryed to click on "new" --> "FPGA Target" but nothing happens.
Message 3 of 14
(4,506 Views)
The main problem is that, when I select New target and devices ---> cRIO , the window "Select Programming Mode" does not appear and I can not select "Scan Interface" and the use of C Series Modules.
Message 4 of 14
(4,495 Views)
Stupid question here: are you sure the chassis is connected to the controller?  Because it sounds like the chassis is not being detected.
And what software do you currently have loaded onto the cRIO controller?  A screen shot of MAX with everything from the cRIO expanded would tell me what I am looking for here.
GCentral
Message 5 of 14
(4,487 Views)
It sounds like things can be seen and are connected right if they can see things in DSM.
Is the RT Module installed?  You mentioned LV and the cRIO drivers.  But, that doesn't mean you have RT or FPGA installed.  You wouldn't need FPGA.  But, you certainly need the RT Module to get the functionality you want from the project.
Message 6 of 14
(4,478 Views)
This is the software installed on my cRIO. (I've installed everything was available).
Message 7 of 14
(4,459 Views)
How can I understand if the RT Module is installed yet? And how can I install it in case it is not installed yet?
Message 8 of 14
(4,458 Views)
The simplest way would be to just try to install LabVIEW RT.  It will not install again if it is already installed.
GCentral
Message 9 of 14
(4,441 Views)
The RT Module was not installed. Now I've solved the problem!
Thank you very much everybody for your kind help! 😄
Message 10 of 14
(4,423 Views)
