‎07-04-2006 02:28 PM
‎02-02-2007 10:07 PM
‎02-27-2007 11:21 AM
Hi Tim,
I downloaded the new NI-HSDIO driver and I could test the streaming to disk sample. I could stream up to 8MHz, which is useless as I was trying to reach 32MHz. I´m using an Advantech Industrial FSBC with a 2.4GHz pentium 4 processor and 1GB of DDR/266 ram. I asked advantech for a faster board (and memory) and I´m gonna try it to see how fast it can get. Which computer have you used in your tests?
Rodrigo
‎02-27-2007 11:30 AM
‎02-27-2007 11:32 AM
‎02-27-2007 11:43 AM
Tim,
As far as I know, the 6561 works only with 2byte wide data. I tried to set it with 1byte data width but I couldn´t, as it returns an error when fetching data. Is there a workaround to solve it?
Rodrigo
‎02-27-2007 12:16 PM
‎02-28-2007 06:18 PM
Hi Tim and Rodrigo,
We have discovered an issue with acquisitions using the 6561/2 in single data rate mode with a datawidth=1 byte. When this configuration is used, the acquired data will be an array of 0's. We are working to resolve this issue as fast as possible. This issue will be fixed in a future HSDIO driver. If you need to acquire data using the 6561/2 in single data rate mode with a datawidth=1 byte, please send me your email address and I will be glad to discuss potential solutions with you.
Ryan
‎03-01-2007 06:16 AM
Hi Ryan,
That would be good if I could set datawidth to 1byte as I would decrease the amount of allocated memory and it won´t be necessary to convert the captured data to an 8bit integer. But if you say that using 1byte the aquisition won´t speed up, then I'm not sure if it will be necessary. If you could mail me, my e-mail is modugno@opto.com.br.
Rodrigo
‎02-11-2008 03:04 AM
Did you all manage to stream the data at 50MHz? I am curious as I am now facing the same problem, pls help if u can, my email address is tkphone@ntu.edu.sg,
Thanks a lot,
