12-08-2021 04:17 PM
Hi all,
I have a curious scenario,
I'm using a DAQ 6210 to read the rpm's of a motor using an encoder, this VI is in charge of reading the data of the DAQ, this VI was working perfectly in a test equipment while I was debugging it.
But once the IT department installed their software the VI stopped working and I'm getting the error -200279 something about a buffer overflow,
I'm reading the data using the single capture method.
has anyone encounter something similar after IT installed their software and how do you managed to solve it without removing the IT software
if you need additional information to solve this please let me know,
thanks to all 🙂
12-10-2021 09:56 PM
Read the current input buffer and Try to increase the input buffer using property node
12-11-2021 08:34 AM
@edmoac wrote:
Hi all,
SINGLE CAPTURE?
I think not! You really have two glaring bugs here. Both of which are related to the fact that you let the user have access to the Run Arrow.
Plus your block diagram constant of continuous samples is insane for single acquisition
Seriously your IT people expect to interact with running software. It would be simple to slip this code into a producer consumer (Events) template and give the user a "Start/Stop Acquisition(s)" button.
