NI-488: Nonexistent GPIB interface, Text file opening
I have attached the missing code and the error image here.
Suma
Message 11 of 16
(1,168 Views)
I need to open only once hence i removed the while loop in main, and De-allocation function in variant selection vi.
Path i have given by including extension .txt, still i am receiving the same error.
Suma
Message 12 of 16
(1,162 Views)
Then apparently something is still wrong with your file path.
Use all the debugging tools you have available to you to figure out why the file paths don't exist.
Message 13 of 16
(1,160 Views)
Accepted by JÞB
Who created that subVI to strip and Build Paths?
Have you checked your filepath to see if it is correct or not?
On my system the problem is that you are stripping your file path twice, you should only strip it once to get rid of the VI name.  Right now you are getting rid of the VI name and the name of the folder that the VI is in.
Message 14 of 16
(1,153 Views)
Stripping length was the problem, its solved now.
Thank you so much!
Message 15 of 16
(1,150 Views)
Thank you so much!
And marked .
You don't have to say thanks,  although it is appreciated,  that kudos button does that for you.
"Should be" isn't "Is" -Jay
Message 16 of 16
(1,147 Views)
