I have tried to aquirre data using the DAQ-assistant and a NI-4351 (for PCI) DAQ-card. However, the assistant doesn't recognize or cannot find the device, eventhough it works perfect in the MAX test panel. Is th NI-4351 card not compatible with the assisatant?
No, the NI-4351 is not compatible with the DAQ Assistant. In LabVIEW, go to Help >> Find Examples, this will open the NI Example Finder. Double-click on Hardware Input and Output >> Traditional DAQ >> Analog Input >> General.
In this folder you will find several example VIs that are written for this card and should help you get started. The names of these VIs start with "NI 435X".
Be sure you see PCI-4351 or PXI-4351 in the list of "devices that can run this example," which is the box in the lower right corner of the example finder.
