.NET assembly and packed project lirary warnings
I am using packed project liobrary that references WinSCP dll located in
C:\Program Files(x86)\WinSCP\WinSCP.dll
when I build library LabVIEW makes copy of this dll to destination folder of the build.
This is fine for me but then this error is displayed when I open compiled library:
Why this happens?
Is there a way to tell LV to leave this dll in the same place?
(2,173 Views)
That's uncanny! I had exactly the same issue with the same DLL only a few days ago and spent ages trying to figure it out, until I stumbled across the following thread:
https://forums.ni.com/t5/LabVIEW/NET-Assembly-in-Packed-Library-Bizarre-Behavior/td-p/3815758
Basically, it's a known bug in LabVIEW (CAR #720595). If the .NET reference is stored in the class's private data it doesn't adjust the links to the PPL DLL.
To workaround this, store the reference as a common .NET class (e.g. System.Object) inside the class data and then use accessors to type cast it back to the WinSCP class.
Using LV2018 32 bit
Highly recommended open source screen capture software (useful for bug reports).
https://getsharex.com/
(2,094 Views)
