05-25-2006 12:52 PM
05-26-2006 05:00 PM
05-30-2006 10:52 AM - edited 05-30-2006 10:52 AM
I was a bit puzzled by this myself until someone suggested I use the "color sucker" tool to find out what the current colors of the enums were.
The color sucker tool (aka eye-dropper) can be used by selecting the paintbrush tool and holding CTRL on the keyboard. Now left-click the item you want to check the color of. Right-click any object to bring up the color picker, and look at the colors in the history. The one furthest to the right (that isn't "empty") is the color you just picked up with the color sucker.
You'll notice that on the problematic enums, the background color is "Hilight Text". This is a system color that will change depending on the theme you use. On the silver theme, it is black or near-black. On the others it is white or near-white.
When picking colors, you might want to be careful to watch the text next to the curently selected color box. If it has RGB values, this is safe (theme-independent). It's also safe to use named colors in the "User" list, such as "Control Background". But if the named color is a system color, it can change depending on your theme.
Disclaimer: I don't know if color sucker or eye dropper is the "official" term for this tool. 🙂
Message Edited by Jeff B on 05-30-2006 10:54 AM
05-30-2006 04:33 PM
