Rami,
I suspect that you have a race condition. The widespread use of local variables frequently leads to race conditions. Your subVI (Spatial Logic Sub_2.vi was not included) so I cannot run the VI. You have no way of knowing whether the subVI or the inner case structure will execute first, because there is no data dependency between them.
I think a shift register or a few and some dataflow thinking would allow you to eliminate the inner case structure, the local variables, and, probably, most of your problems.
Some of the SPi are indicators and some are controls. How are they used?
The last case of the inner loop retursn to Case 1. Would case 0 be better?
As for the second time through issue, it may be related to the Elapsed time function Auto Reset. From the help file: "Resets the start time to the value in Present (s) when the Express VI reaches the Time Target (s)." If more than 5 seconds elapses between the first time you use this and the next, it will exit immediately on the subsequent calls.
Lynn
