I created and signed some vis, converted them to llbs and then loaded them onto a unix box where they are called by cgi scripts. On several pcs, it works perfectly but on others, I get the error message that the top level vi is not signed or validation failed, load error code 34. All pcs are accessing the same llbs from the same unix box, so it is something about the way some of the machines are set up.
