My high speed serial pxie-7902R can't finish generating intermediate files
I wrote a very simple test program with labview fpga on target 7902R, but it can't generate intermediate files with error code 1. What should I do to fix it?
The error information is like this:
An internal software error has occurred. Please contact National Instruments technical support at ni.com/support with the following information:
Set Permissions in 659XR_GenerateVHDL.vi:3340001->niFpgaTopLevelGenCallTargetSpecificVI.vi->niFpgaHandleConstraintsAndMiscFPGAFiles.vi->niLvFpgaTopModGen.vi->niLvFpgaTopModGen.vi.ProxyCaller
<APPEND>
C:\Program Files\NI\LVAddons\nihss\1\Targets\NI\FPGA\RIO\659XR\PXIe-7902R\FpgaFiles\Templates\PkgChevellePoscROM.vhd
(1,635 Views)
Your code reduces to a no-op.
Try feeding a feedback node into the negate instead of a constant. Taht way, it will simply toggle the value at the clock rate.
Currently, your entire loop can be removed by Xilinx because it generates a constant output. As such, Xilinx ends up having essentially nothing to compile.
(1,633 Views)
Actually I tried mmwave reference project and it doesn't work either.
(1,614 Views)
Are these cloud compiles or local compiles?
Whichever it is, try the other...
Just to rule out one variable.
Or does this error occur before Xilinx even gets involved?
(1,610 Views)
