09-16-2007 10:59 AM
09-17-2007 05:59 AM
@falkpl wrote:
IIf I start a new VI it is not japanese font, What happened?
This sounds contradictory to your question.
Do you WANT font in Japanese or you DONT WANT in Japanese ?
Please clarify...
09-17-2007 06:26 AM
09-17-2007 07:29 AM
No I dont want Japanese or chinese (food but not fonts).Very strange bug, the application settings = en, the system is in US settings. When I deleted the project and went to the last version, all my text was back in english. This was my temporary fix, didnt lose too much work but srtange none the less. The OS is vista, LV for the project is 8.0 and the font was MS San Sanrif size 18. All the lables and default text became Japanese or possible Chinese when I opened it I tried changing fonts, set the font back to default, added a new VI and I was back in english. Just dont know what happened. At least I was aple to go to the previous version (I make backups every few hours of coding). I very rarely have to internationalize my apps so I am unfamillar with the language settings.
Paul
02-11-2010 06:24 PM
02-12-2010 10:48 AM - edited 02-12-2010 10:48 AM
Hi dycor,
To clarify some things:
1. Are these projects already written in different languages? Are they written in different versions of LabVIEW (LabVIEW japanese, for example)
2. When you open a single VI in the project without opening the project, does the same thing happen?
3. When this issue occurs, does the language change for the entire environment? Does the language change on the operating system itself (start menu, for example)?
02-12-2010 12:25 PM
This issue is also being discussed here:
http://forums.ni.com/ni/board/message?board.id=170&thread.id=191355&view=by_date_ascending&page=1
Here are some answers to Smootastic's questions:
1. No different languages - just U.S. English.
2. When LabVIEW is not running, I double click in the VI and yes it still has the Asian Character set. Sometimes I have seen it, when built into an EXE, with squares instead of characters. Other times blank characters that I can copy and paste into notepad to see the digits. Some controls still are in English. See the attached picture.
3. My PC and most of the other front panels are still in English.
Usually my source code VIs are ok.. but once they get saved with the weird fonts they always open that way and I have to restore from a previous version. When I see these characters in my EXE I just rebuild it and usually the problem is fixed - I think I restart LabVIEW before rebuilding though.
Thanks for looking into this issue.
Mike
Dycor Technologies Ltd.
02-13-2010 02:46 AM
Hi
I do not think that the language (japanese or chinese ..) matters. It is a problem of font replacement;I have a similar (worse) problem, described here http://forums.ni.com/ni/board/message?board.id=170&message.id=474835#M474835
N
02-15-2010 10:08 AM
Hi Mike and N,
Take a look at this KB and let me know if this helps:
02-15-2010 11:45 AM
