03-20-2018 05:14 AM
I tried connecting my cRIO 9073 to my PC directly through ethernet and via a network switch as well. Default IP, subnet mask, DNS address, gateway and Time Server IP are all set to 0.0.0.0 at powerup (as mentioned in its datasheet). Since I can't get my PC on the same subnet, I am not able to locate this device in MAX. I even tried to power up cRIO in safe mode but no gain. Can anyone help me with this?
03-20-2018 06:19 AM
Since the subnet mask is 0.0.0.0, you should be able to communicate with the cRIO by setting the same mask and any IP address on your computer.
Did you check the cRIO Part Number as suggested in the user manual?
03-20-2018 07:10 AM
Yeah..but PC IP address cannot be 0.x.x.x.
03-20-2018 08:03 AM - edited 03-20-2018 08:04 AM
If the subnet mask is allowed to be 0.0.0.0, any IP address should be good (any but 0.0.0.0, of course, which is the address of your device).
Try with 1.1.1.1. I agree it's somewhat bizarre. Never tried myself.
03-23-2018 06:11 AM
No, even the subnet mask cannot be made 0.0.0.0.
03-23-2018 06:58 AM - edited 03-23-2018 07:03 AM
please don't ever use 0.0.0.0 as an IP address
https://en.wikipedia.org/wiki/0.0.0.0
choose something from here
https://en.wikipedia.org/wiki/Internet_Protocol_Version_4#Private_networks
also i'm quite sure my crio was initially configured to get IP from DHCP,
if that fails, it will have an IP somewhere in the 169.254.*.* subnet
03-23-2018 08:21 AM
maybe this thread helps you https://forums.ni.com/t5/LabVIEW/Determine-a-cRIO-IP-address-when-MAX-cannot-find-the-target-NI/td-p...
