My Second Nugget - Easy Create Icons
Did you know that there is a very easy way to create icons in LabVIEW?
This is my first attempt at a screencast. Anyone know if it is possible to embed a screencast in the forums? I don't think I have ever seen one.
LabVIEW 2012
Message 1 of 10
(5,811 Views)
Switch to HTML editing, then paste the "embed" link. It will show as below:
Unable to display content. Adobe Flash is required.
Message 2 of 10
(5,785 Views)
I don't see what this has to do with "creating icons".  You're not creating anything, you're just assigning this icon to this VI and that icon to that VI, by dragging them, something LabVIEW has been able to do for 20 years.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 3 of 10
(5,784 Views)
Well you are right. It is not technically "creating" the icons but rather asigning them. Maybe you could say the same thing about using the glyphs that ship with LabVIEW?
Even though dragging an image to the icon has been a LabVIEW feature for quite some time there is probably somebody out there who didn't know about it. I don't think sharing tips should be limited to new features Smiley Happy
LabVIEW 2012
Message 4 of 10
(5,765 Views)
*I* didn't know. So thanks and kudos for this one.
It actually doesn't work directly for me (drop a png from Win Explorer to LV 7.1: first-drag-drop it on the FP, then on the Icon works). That's propably why I wasn't aware of it.
For small tricks, consider posting them to the micro-nugget thread.
Felix
Message 5 of 10
(5,751 Views)
Wow, my very own vi named after me, sandwiched in-between Altenback, Darin and Ben. All my dreams are finally coming true Smiley Very Happy
Didn't know you could do this either, nice.
"Everything should be made as simple as possible but no simpler"
Message 6 of 10
(5,724 Views)
FYI: All I see in Altenbach's message is a big white space after his message text.  Most sites that host videos have been blocked here at my workplace, including YouTube, screencast.com, etc.
Message 7 of 10
(5,669 Views)
Agreed!
paraphrasing from Proverbs;
"I wise man goes into his storehouse and brings frth treasures both onld and new."
A clasic "I didn't know that." is being able to control which of the inputs to a two input operator gets wired when doing an "insert" (hold cursor slightly above or below wire).
Another is being able to control which digit of a control increments by moving the cursor in the number and using up/down keys.
Or a control on the root of the BD can help avoid buffer copies...
Although they are not earth shaking, there is no harm in bringing those tips up occationally.
Thanks Steve for your Nuggets!
In my case I always learned something from posting my Nuggets. I hope you reap similar benfits.
Ben
Message 8 of 10
(5,651 Views)
My apologies for being grumpy yesterday.
My point was not that such things should not be posted - just that calling it "creating" was misleading and incorrect.
In any case, I'm sorry it came out the way it did.
Steve Bird
Culverson.com
LinkedIn
Message 9 of 10
(5,629 Views)
No offense taken. Bad choice of words but I wasn't trying to be misleading Smiley Happy
LabVIEW 2012
Message 10 of 10
(5,602 Views)
