I have a working COM driver (VB, VC++, and others) that does not function in LabView 6.0. After I setup the Automation Refnum, Automation Open, and then either Invoke Node or Property Node shows no methods or properties. Am I doing anything wrong?
I found the answer to my question. I needed to include the following line in the LabView.INI file: enableCustomInterface=True This allowed full access to my COM driver.
Matt, great detective work. My question to you is, where and how did you come across this? Is there some documentation that has the peculiarities of the LabVIEW.INI file?
