Must multiplot charts have all equal length data sizes?
I would like to place 2 plots in 1 chart.
The problem is that the 2 plots might be different sizes.  Is this possible?  Or do I have to use a graph?  I would like to use the chart because it has the digital display option which shows the last data point added.
(2,451 Views)
Hi Javiucsd,
I don't think it is possible in Chart, You can do it in Graph.
As far as retaining last data is concerned, you can use shift register to store data.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(2,442 Views)
It still a little known that you can use a Waveform datatype with a chart to plot multiple signals that have different sample rates or are aperiodic.
I shared a lot of info and notes regarding Waveform Charts in this thread.
read the rules and details closely. There are some subtle things that may suprise you if you don't think about them.
I hope that helps,
Ben
(2,430 Views)
