12-04-2011 10:09 AM
I created a custom LabView instrument to use in Multisim, with accordance to this tutorial: http://zone.ni.com/devzone/cda/tut/p/id/5635#toc2
I copied it to the .../Circuit Design Suit/lvinstruments folder, but I couldn't call it in Multisim from the Simulate>Instruments>LabView Intrument menu as listed above. I realize the tutorial given refers to LabView 8.0, but it was the only one i could find on the subject. I would be very greatful if someone could find a solution for me.
Best Regards
12-06-2011 08:03 AM
Dear rsmarinoff,
I found this forum topic with a similar question: http://forums.ni.com/t5/Circuit-Design-Suite-Multisim/How-to-add-LabVIEW-instruments-to-Multisim/m-p...
The Multisim 11 came out in May 2011, but the LabVIEW 2011 was released a littlebit later.
The Multisim is compatible until LabVIEW 2010. If you need, you can send me your project, and I can convert your LLB files into LV 2010.
You can send it to tamas.szekely@ni.com
Or you can ask also in the Downconvert VI Request discussion forum: http://forums.ni.com/t5/LabVIEW/Downconvert-VI-Requests/m-p/1067229?requireLogin=False
Best Regards,
Tamas
