Greg McKaskle wrote:
> > I want to give each plot the name of the measurement, but 1 was only
> > able to chance the name of Plot 0 with "Property Node-Plot name" and not
> > the names of Plot 1 and higher. How can i do that?
> If you inspect the output of the property node, you will see that
> it is returning an error. You cannot set a property on a plot
> that has not been allocated.
> First, write some data to the graph for each plot. Even an empty
> array or waveform will allocate the plot, then set the properties.
> Another way to allocate the plots is to grow the legend to show
> the plot and plot name.
Even then, you have to manually do something to the new plot (at least
in 5.1). If you grow the legend to 2 plots, you have to
do something
like setting the color or line type.
Only then can you work with the second plot programmatically.
Mark
